• United States
IBM?
  • Site map
IBM?
  • Marketplace
  • Close
    Search
  • Sign in
    • Sign in
    • Register
  • IBM Navigation
IBM Developer Answers
  • Spaces
    • Blockchain
    • IBM Cloud platform
    • Internet of Things
    • Predictive Analytics
    • Watson
    • See all spaces
  • Tags
  • Users
  • Badges
  • FAQ
  • Help
Close
Name
Community
  • Learn
  • Develop
  • Connect
Discover IBM
  • ConnectMarketplace
  • Products
  • Services
  • Industries
  • Careers
  • Partners
  • Support
10.190.13.206
Refine your search by using the following advanced search options.
Criteria Usage
Questions with keyword1 or keyword2 keyword1 keyword2
Questions with a mandatory word, e.g. keyword2 keyword1 +keyword2
Questions excluding a word, e.g. keyword2 keyword1 -keyword2
Questions with keyword(s) and a specific tag keyword1 [tag1]
Questions with keyword(s) and either of two or more specific tags keyword1 [tag1] [tag2]
To search for all posts by a user or all posts with a specific tag, start typing and choose from the suggestion list. Do not use a plus or minus sign with a tag, e.g., +[tag1].
  • Ask a question
Watson IoT edge platform installation problems
55000128KP gravatar image
Question by Dave Rensberger  (20) | Feb 06 at 11:04 AM iotwatson-iotwatson-iot-edge-analyticsedge-analytics
When trying to install the Watson IoT edge platform on an x86(64 bit) PC running Ubuntu, I get the following error:
 $ sudo apt-get install horizon-wiotp
 Reading package lists... Done
 Building dependency tree
 Reading state information... Done
 Some packages could not be installed. This may mean that you have
 requested an impossible situation or if you are using the unstable
 distribution that some required packages have not yet been created
 or been moved out of Incoming.
 The following information may help to resolve the situation:
 The following packages have unmet dependencies:
  horizon-wiotp : Depends: horizon (= 2.17.2~ppa~ubuntu.xenial) but 2.20.5~ppa~ubuntu.xenial is to be installed
 E: Unable to correct problems, you have held broken packages.
I noticed a similar problem reported for Raspbian, but the prescribed solution didn't work on x86. I'd once forced it to work by hacking up the installation procedure, but I don't remember exactly how.
What is the correct way to install the IoT Edge Platform? Is there a plan these dependency issues? This has been broken for months now.
Thanks, --Dave
People who like this
  0
Comment
10 |3000 characters needed characters left characters exceeded
  • Viewable by all users
  • Viewable by moderators
  • Viewable by moderators and the original poster
1 reply
  • Sort:
270007Q7XS gravatar image
Answer by Leandro Cordeiro David (227) | Feb 08 at 12:25 PM
Probably similar to this question: https://developer.ibm.com/answers/questions/481558/watson-iot-edge-installation-issue-on-raspberry-pi/
Can you try this (for raspberry)
 apt-get install horizon-cli=2.17.14~ppa~raspbian.jessie
 apt-get install horizon=2.17.14~ppa~raspbian.jessie
Or change raspbian.jessie for ubuntu.xenial for ubuntu installation
Comment
  0   Show 2   Share
55000128KP gravatar image Dave Rensberger (20)   Feb 11 at 06:25 PM 0
Hi Leandro,
That question was the one I was referring to when I said "I noticed a similar problem reported for Raspbian". As I stated, though, just translating that workaround into ubuntu.xenial doesn't work:
 bws@ubuntu-amd-squiddy:~$ sudo apt-get install horizon-cli=2.17.14~ppa~ubuntu.xenial
 E: Version '2.17.14~ppa~ubuntu.xenial' for 'horizon-cli' was not found
Isn't it possible for you to to just fix this on the apt server side (maybe by just reverting the packages to whatever they were when they last worked)? The way things are now, it's impossible to install and it's been that way for several months now.
--Dave
55000128KP gravatar image Dave Rensberger (20)   Feb 13 at 10:50 AM 0
I eventually found something that works (although I'm not sure it's the best solution). I had to download all of the *.deb files for the "lowest common version" of all of the packages, which turns out to be 2.17.9 for the _amd64 architecture:
 sudo dpkg -i horizon-cli_2.17.9~ppa~ubuntu.xenial_amd64.deb
 sudo dpkg -i horizon_2.17.9~ppa~ubuntu.xenial_amd64.deb
 sudo dpkg -i bluehorizon_2.17.9~ppa~ubuntu.xenial_all.deb
 sudo dpkg --force-all -i horizon-wiotp_2.17.9~ppa~ubuntu.xenial_all.deb
--Dave
Follow this question
160 people are following this question.
Answers
Answers & comments
Related questions
How to configure or enable a Cloud Foundry app to be available as an Edge Service? 1 Answer
Watson IoT edge installation issue on raspberry pi 3 4 Answers
How to actually use Watson IoT Platform Edge once it's installed? 0 Answers
HTTP 503 error when running wiotp_agent_setup 1 Answer
Error when running wiotp_agent_setup 0 Answers
  • IBM Developer Terms of use
  • Report Abuse
  • Cookie Preferences
Powered by AnswerHub
Authentication check. Please ignore.
  • Anonymous
  • Sign in
  • Create
  • Ask a question
  • Spaces
  • API Connect
  • Analytic Hybrid Cloud Core
  • Application Performance Management
  • Appsecdev
  • BPM
  • Blockchain
  • Business Transaction Intelligence
  • CAPI
  • CAPI SNAP
  • CICS
  • Cloud Analytics
  • Cloud Automation
  • Cloud Object Storage
  • Cloud marketplace
  • Collaboration
  • Content Services (ECM)
  • Continuous Testing
  • Courses
  • Customer Experience Analytics
  • DB2 LUW
  • DataPower
  • Decision Optimization
  • DevOps Services
  • Developers IBM MX
  • Digital Commerce
  • Digital Experience
  • Finance
  • Global Entrepreneur Program
  • Hadoop
  • Hybrid Cloud Core
  • IBM Design
  • IBM Forms Experience Builder
  • IBM Maximo Developer
  • IBM StoredIQ
  • IBM StoredIQ-Cartridges
  • IIDR
  • ITOA
  • InformationServer
  • Integration Bus
  • Kenexa
  • Linux on Power
  • LinuxONE
  • MDM
  • Mainframe
  • Messaging
  • Node.js
  • ODM
  • Open
  • PowerAI
  • PowerVC
  • Product Insights
  • PureData for Analytics
  • Push
  • QRadar App Development
  • Run Book Automation
  • Search Insights
  • Security Core
  • Storage
  • Storage Core
  • Streamsdev
  • Supply Chain Business Network
  • Supply Chain Insights
  • Swift
  • UBX Capture
  • Universal Behavior Exchange
  • UrbanCode
  • WASdev
  • WSRR
  • Watson
  • Watson Campaign Automation
  • Watson Content Hub
  • Watson Marketing Insights
  • dW Answers Help
  • dW Premium
  • developerWorks Sandbox
  • developerWorks Team
  • Watson Health
  • More
  • Tags
  • Questions
  • Users
  • Badges
