Win $20,000. Help build the future of education. Answer the call. Learn more
Auto scale your applications during the holiday season
During the holiday season it’s common for business websites to crash as large numbers of users visit the sites to send gifts to their loved ones. Whether it be, Black Friday, Eid, Christmas, or Boxing day, businesses might potentially lose a lot of revenue if their infrastructure is not set up to handle a heavy load.
Businesses can leverage the cloud to scale their applications with the IBM Auto Scaling service, and they can test their loads using the Load Impact service.
Learning objectives
After completing this tutorial, you’ll know how to:
  • Use the Auto Scaling service to scale your application.
  • Use the Load Impact service to test your application.
To follow this tutorial, you need to have:
Estimated time
Completing this tutorial takes about one hour: 30 minutes for the prerequisites and another 30 minutes for the steps.
Steps
Attach the IBM Auto Scaling Service to your application
Navigate to your web app and click the Overview tab
alt
Click Create connection and connect the Load Impact service that you provisioned.
alt
As soon as you connect, you see an option to restage your application. Click Restage so that the service becomes available for your web application.
alt
Set up the IBM Auto Scaling Service according to your requirements
Navigate to the Auto Scaling service you recently attached to your web app. Select the option to view the policy configuration, and create an auto scaling policy.
alt
In this configuration, you can scale your app using the following four metrics:
  1. Heap
  2. Memory
  3. Throughput
  4. Average time
Note: Use the advanced steps to configure more complex auto scaling for Node.js and Swift.
alt
Different auto scaling policy configurations are available based on the metric selected. This example includes a policy configured for the memory to scale out when the upper threshold goes above 30 percent of the memory and to scale in when the lower threshold goes below 10 percent of the memory. You can add multiple rules, but make sure you do not add conflicting rules which might cause an issue.
If you use advanced policies, you can set application characteristics for the following four metrics:
  1. Statistic window
  2. Breach duration
  3. Cooldown period (scaling out and scaling in)
  4. Time periods
For example, if you know that your application is heavily used on Christmas Day, you can add a specific start and end date along with the number of instances you want your application to scale out to.
alt
Review the policy configurations, and make sure to enable the policy.
alt
Perform the load test using Load Impact
Navigate to the Load Impact service, and open the Load Impact dashboard. Create a test and add the link to the application, as shown in the following screen capture:
alt
Add a scenario, and run the test to successfully test it out, as shown in the following screen captures:
alt
alt
You can review the scaling history in the Auto Scaling service for the implications of the Load Impact service.
alt
Summary
In this tutorial, you learned how to use the Auto Scaling and Load Impact services to scale your IBM Cloud application during a heavy load of visitors.
