Archived | Integrate Watson Assistant with Facebook Page using Node-RED
Archived content
Archive date: 2019-07-02
This content is no longer being updated or maintained. The content is provided “as is.” Given the rapid evolution of technology, some content, steps, or illustrations may have changed.
IBM Watson Assistant has been proven to be helpful in managing users interactions with your business through different platforms. Like many other platforms, Watson Assistant can be linked to your Facebook page as well. When you link your Watson Workspace with your Facebook page, users can interact with your page whenever they want and get a response in seconds. You do not need to hire representatives to handle inquiries on your Facebook page. Watson Assistant can do that for you in a more efficient and responsive way.
After completing this guide, you can also refer to the Use Graph API to extract Facebook username and set Watson Assistant context in Node-RED how-to so that our chatbot can call the user by name.
Learning objectives
In this guide, we shall go through the steps involved in creating a Node-RED boilerplate available in IBM Cloud and link Watson Assistant to a Facebook Page using Node-RED flows.
To follow this guide, you need to have:
Estimated time
If you fulfill the prerequisites of this guide then the following steps would take around 20 to 30 minutes.
Steps
Create a Node-RED boilerplate application
Create a Node-RED Boilerplate, by going into the IBM Cloud Catalog and searching for Node-RED.
alt
Click Node-RED Starter, give the application a name, and click Create. Once the application’s status is Running, open the route (URL) of the application.
When you open the route of Node-RED application, you will be directed to the welcome page. Follow the directions there to add credentials for your Node-RED application. These credentials are unique for you and will be required the next time you use this instance of Node-RED.
alt
After you set the password, continue by clicking Next. You will be prompted to enter your credentials, and then you will be directed to the Node-RED Flow window.
Obtain Facebook credentials
Review Facebook’s documentation for Setting Up Your Facebook App and ensure that you have completed each of the requirements.
Go to app dashboard under Facebook App and create a new app.
alt
Click Set Up under Messenger Grid.
alt
Under Token Generation, select the page with which you want to integrate the Chatbot.
Page Access Token will be generated after giving the permission to it.
Copy the token for use in the next two steps.
Create a Facebook Messenger verification webhook
Drag and drop http input, function, http response, and debug node and link them as shown below (ignore the nodes name for now):
alt
Open the function node, and name it Subscribe. Enter the following code, ensuring that you populate the facebookToken variable with the token generated in the previous step:
const facebookToken = '';
var mode = '';
var vtoken = '';
var challenge = '';
if (msg.payload['hub.mode']) {
    mode = msg.payload['hub.mode'];
if (msg.payload['hub.verify_token']) {
    vtoken = msg.payload['hub.verify_token'];
if (msg.payload['hub.challenge']) {
    challenge = msg.payload['hub.challenge'];
if ('subscribe' == mode && facebookToken == vtoken) {
    msg.payload = challenge;
return msg;
if ('subscribe' == msg.payload['hub.mode'] && facebookToken == msg.payload['hub.verify_token']) {
    msg.payload = msg.payload['hub.challenge'];
return msg;
Double-click the http input node, name it Verification Webhook, and set URL to /mybot.
alt
Setup webhooks
Under Webhooks, click Setup Webhooks.
alt
Provide a callback URL (for example, https://example.com/mybot) that matches the path provided in the previous step.
In the Verify Token text box, provide the Facebook token generated in step 2.
Check the checkbox of messages and click Verify and save.
If you get error when saving, verify that you have provided the right Callback URL and see in the Node-RED flow that your flow is Deployed.
Once it is verified. Select the Page and Subscribe.
Create Node-RED Messenger Listener
Drag and drop Input http, Output http response, Function, and Two output debug nodes. Double-click the function node and set output to 2. Name it Look for Messages and click Done
alt
Wire them like below:
alt
Double-click the input http node and specify the method as POST and the URL as /mybot. Name it Messenger Chat Listener.
Double-click the function node, and enter the following code:
if (msg.payload.object && 'page' == msg.payload.object) {
    if (msg.payload.entry) {
        var entry = msg.payload.entry;
        for (var i = 0; i < entry.length; i++) {
            var pageID = entry[i].id;
            var timeOfEvent = entry[i].time;
            var messaging = entry[i].messaging
            for (var j =0; j < messaging.length; j++) {
                if (messaging[j].message) {
                    msg.messagingEvent = messaging[j];
                    node.send([msg,null]);
return [null, msg];
Double-click the second debug node (msg.payload). In the Output field, enter msg.messagingEvent, and name it MessengingEvent from Messenger and then click Done.
alt
Click Deploy and Go to the page and send a message. Check the Debug sidebar and you should be able to see the message now sent from the Messenger.
Current flow should look like this:
alt
Create Node-RED Messenger Writer
Install Facebook-Messenger node first. From the hamburger menu on Node-RED, go to Manage Palette. Search for “Facebook” and install the writer node.
alt alt
Now drag and drop function, facebook messenger, and debug node and wire them as shown below:
alt
Open the new function node and rename it to Set up response. Enter the following code:
msg.facebookevent = msg.messagingEvent;
msg.payload = 'Hello, this is all I say for now.';
return msg;
Provide your facebook token in the facebook node.
Deploy and send a message on the page and you should now be able to see the response.
Integration with Watson Assistant
Remove the wire from the highlighted Listener and Writer nodes.
alt
Drag and drop function and output link node.
Code for the function:
msg.fromMessenger = true;
msg.payload = msg.messagingEvent.message.text;
return msg;
Connect the Look for messages node, new function and output link node.
alt
Also, remove the line that contains This is all I say for now from the Set up response Node.
Create a new work flow, drag and drop input link, Assistant, function, and output node.
alt
Double-click the Assistant node and enter the credentials of the Assistant service from the Dashboard of IBM Cloud (Username, Password, Workspace-ID).
Code for function:
output = msg.payload.output.text.join(' ');
msg.payload = output;
if (msg.fromMessenger) {
    return [msg,msg];
} else {
    return [msg, null];
Double-click the output node of Flow 1, as shown in the picture.
alt
Click the checkbox that links to Flow 2 and click Done.
Drag and drop Input link node in the Flow 1 behind the Set Response Node.
alt
Now go back to the Flow 2 and double-click the output link and check the checkbox of input link of Flow 1.
alt
alt
Click Done and Deploy the App.
Now, when you interact with the Page, you will get responses from Watson Assistant.
Summary
In this tutorial, we learned how you can get started with the Node-RED Starter Boilerplate. We also learned how to make productive use of the Node-RED tool and integrate Watson Assistant with the Facebook Page.
