Knative routing
Knative is an open source platform that extends the capabilities of Kubernetes to help you create modern, source-centric containerized and serverless applications. Knative integrates with Istio to ensure that your workloads can be easily exposed on the Internet, monitored and controlled. This tutorial focuses on these traffic management capabilities of Knative.
Objectives
In this tutorial, you’ll learn how to:
- Roll out a new revision of an application.
- Roll back to an earlier revision of an application.
Prerequistes
This tutorial assumes that you completed the Knative 101 Labs, which introduces the basic Knative concepts and provides instructions for creating an IBM Cloud Kubernetes Service cluster and installing Knative. You will need the cluster to complete this tutorial.
Complete the following exercises if you have not already:
- Install developer tools (ibmcloud, kubectl, kn)
- Create a Kubernetes cluster on IBM Cloud
- Install Knative and Istio on your cluster
- Set up your private container registry
Also you need to have Docker installed.
Deploy the sample application
A user can work with Knative in two different ways:
- By managing the low-level Knative resources (route, configuration, etc.) directly.
- By managing the high-level Knative service resource and let Knative manage the underlying low-level resources.
For the purpose of getting started and keeping things simple, let’s assume that we are using the latter approach.
This tutorial uses a helloworld sample program that was adapted from this sample.
Clone this repository so that you can use it to build and deploy the same program.
git clone github.com/IBM/knative-routing-tutorial cd knative-routing-tutorial
Build the first version of the helloworld-go sample program in the
helloworld1
directory and push it to your container registry. Note that the image is given the tag1
to indicate the first version of the program. You will need to substitute the following values in these commands:<APIKEY>
– the API key that you created in the Knative lab to access your registry.<REGISTRY>
– the domain name of your container registry (e.g.us.icr.io
).<NAMESPACE>
– the name of your namespace in the registry that you created in the Knative lab.docker login -u iamapikey -p <APIKEY> <REGISTRY> docker build -f Dockerfile helloworld1 -t helloworld-go:1 docker tag helloworld:1 <REGISTRY>/<NAMESPACE>/helloworld-go:1 docker push <REGISTRY>/<NAMESPACE>/helloworld-go:1
We’re going to deploy the helloworld-go program by using the helloworld1.yaml file. Let’s take a look at the file.
apiVersion: serving.knative.dev/v1 kind: Service metadata: name: helloworld-go namespace: default spec: template: metadata: name: helloworld-go-simple-response spec: containers: - image: <REGISTRY>/<NAMESPACE>/helloworld-go:1 env: - name: TARGET value: "Go Sample v1"
The configuration of the service is called a revision. This revision is given the name
.You must edit the helloworld1.yaml file to replace
<REGISTRY>
and<NAMESPACE>
with the same values as you used when you pushed the image. After you do that, apply the helloworld1.yaml file to your cluster.kubectl apply -f helloworld1.yaml
It may take a minute for the program to be ready. You can monitor the progress by displaying the service.
kubectl get ksvc helloworld-go
When the output shows the service is ready, you can continue. You should see something like the following.
NAME URL LATESTCREATED LATESTREADY READY REASON helloworld-go http://helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud helloworld-go-simple-response helloworld-go-simple-response True
The above output tells us that the service hostname is
.The hostname for the service follows this general pattern: service name–service namespace.ingress subdomain
The service name and service namespace are determined from the service yaml file.
The ingress subdomain is a public URL providing access to your cluster. You may see a different name depending on what you named your cluster and where it is located.
Now you can curl the helloworld-go application. Substitute your service name in the curl command below.
curl helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
You should see a response message,
Hello Go Sample v1!
Roll out of a new version of the application
Let’s change the sample application to give back a more interesting response than the simple static message.
Build the second version of the helloworld-go sample program in the helloworld2
You will need to replace <REGISTRY>
with the domain name of your container registry (e.g. us.icr.io
and <NAMESPACE>
with the name of your namespace in the registry that you created in the Knative lab.
Note that the image is given the tag 2
to indicate the second version of the program.
docker build -f Dockerfile helloworld2 -t helloworld-go:2
docker tag helloworld:2 <REGISTRY>/<NAMESPACE>/helloworld-go:2
docker push <REGISTRY>/<NAMESPACE>/helloworld-go:2
We could just deploy the new version, by completely replacing the old version of the application.
However, at a certain point you may want to do a more gradual roll out of a new function to users.
This can be done by adding a traffic
object to the service yaml file.
Here is the next yaml file we will use, helloworld2.yaml.
kind: Service
metadata:
namespace: default
spec:
template:
metadata:
spec:
containers:
- image: <REGISTRY>/<NAMESPACE>/helloworld-go:2
traffic:
- tag: current
revisionName: helloworld-go-simple-response
percent: 50
- tag: latest
revisionName: helloworld-go-random-response
percent: 50
In addition to changing the service’s pod configuration to use a different image (the one tagged with 2
), this file uses a new traffic
object to route requests to different revisions.
In this case we want to divide traffic evenly between the previous revision we created helloworld-go-simple-response
and the new revision we’re creating helloworld-go-random-response
You must edit the helloworld2.yaml file to replace <REGISTRY>
and <NAMESPACE>
with the same values as you used earlier.
After you do that, apply the helloworld2.yaml file to your cluster.
kubectl apply -f helloworld2.yaml
Watch for the new revision to become ready by using kubectl get ksvc helloworld-go
as before. When it is, confirm that the route is splitting traffic between the two revisions by using:
kn route describe helloworld-go
You should see something like this:
Namespace: default
Age: 10m
URL: http://helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
Service: helloworld-go
Traffic Targets:
50% helloworld-go-simple-response #current
URL: http://current-helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
50% helloworld-go-random-response #latest
URL: http://latest-helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
Conditions:
OK TYPE AGE REASON
++ Ready 3m
++ AllTrafficAssigned 10m
++ IngressReady 3m
Try using curl
again several times and you should see the response you saw from the first version and some new responses from the second version.
$ curl helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
Hello and have a wonderful day!
Hello Go Sample v1!
When using the traffic
object you can assign a tag
to expose a dedicated URL that routes requests to that revision.
In the yaml file we used the tag current
for the original revision and latest
for the new revision.
You can prefix these tags to the service’s domain name if you need to try out a specific revision.
$ curl current-helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
Hello Go Sample v1!
$ curl latest-helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud
Hello and have a super day!
The use of tag
is optional.
Roll back to an earlier version of the application
What if you discover during your roll out testing that there’s something wrong with the new revision of your service and you don’t want to route users to it?
In that case you can edit the service using
kubectl edit ksvc helloworld-go
An edit window appears, containing the service’s current yaml definition.
Find the traffic
object (the one under spec
, not the one under status
) and change it so that the first revision gets 100% of the requests and the second revision gets 0% of the requests, as shown below.
traffic:
- latestRevision: false
percent: 100
percent: 0
Save the updated yaml file and close the edit window. All traffic now will be routed to the first revision.
Hello Go Sample v1!
Hello Go Sample v1!
Roll forward to the latest version of the application
What if testing went well and you want to route all users to the new revision?
In that case, you can edit the service’s yaml and change the traffic
object in any of the following ways:
- Change the
traffic
object so that the first revision gets 0% of the requests and the second revision gets 100% of the requests.traffic: - latestRevision: false percent: 0 revisionName: helloworld-go-simple-response - latestRevision: false percent: 100 revisionName: helloworld-go-random-response
- Change the
traffic
object to route all requests to the latest ready revision.traffic: - latestRevision: true percent: 100
- Delete the
traffic
object completely. This causes knative to route all requests to the latest ready revision.
Save the updated yaml file and close the edit window. All traffic now will be routed to the latest revision of the service.
Monitoring traffic using IBM Cloud Monitoring with Sysdig
We can use IBM Cloud Monitoring with Sysdig to observe the traffic that is being split between the two revisions of the service.
Follow this tutorial for instructions on provisioning an instance of IBM Cloud Monitoring with Sysdig and configuring your cluster to work with it.
After completing the tutorial, click on the
Dashboards
icon and find theKubernetes Health Overview
dashboard. It is located in theKubernetes
section underDefault Dashboards
. When you have opened the dashboard, complete the following steps:- Click on the options
menu and select theCopy Dashboard
option. - Click the
Copy and Open
button. - When the copied dashboard appears, click
Edit Scope
. - Select
container.label.io.kubernetes.pod.namespace
in the first drop-down box. - Select or type in
Default
in the value box. - Click
Save
In a separate shell, run a loop of curl requests to the
helloworld-go
service as follows.for i in `seq 1 5000`; do curl helloworld-go-default.mycluster6-f2c6cdc6801be85fd188b09d006f13e3-0000.us-south.containers.appdomain.cloud; done
Assuming that the Knative service is still set to route all requests to the latest revision, the dashboard should show all requests going to the
revision. (You may have to click on the10M
or1M
button at the bottom of the window to see recent data.)Try applying the
helloworld2.yaml
file again to split traffic between the two revisions.kubectl apply -f helloworld2.yaml
The dashboard should show requests being split between the two revisions.
Next steps
Congratulations, you completed this tutorial. You learned how to use Knative’s routing capabilities to roll out a new revision of an application and roll back to an earlier revision of an application. So, what’s next? Try Build a Knative serverless web application. You can also explore and discover more Knative content.
