Tutorial
By Animesh Singh, Anthony Amanse | Published October 1, 2017
API ManagementMobile DevelopmentOn Premises
In this code, we show you how to create efficient and scalable RESTful APIs for mobile and cloud applications securely from your business critical applications residing on the mainframe.
IBM z/OS Connect Enterprise Edition provides access to z/OS subsystems, such as CICS, IMS, WebSphere MQ, DB2, and Batch, that use RESTful APIs with JSON formatted messages. The framework provides concurrent access, through a common interface, to multiple z/OS subsystems.
z/OS Connect EE can help to deliver benefits to an enterprise in two ways:
It provides an intuitive workstation-based tool, the z/OS Connect EE API Editor, that enables a developer, with or without z/OS skills, to create RESTful APIs from traditional z/OS based assets. The core business assets that run on z/OS can easily be adapted to the latest mobile and cloud communication techniques and message protocol formats.
Mobile and cloud application developers, inside or outside the enterprise, can incorporate z/OS data and transactions into their applications without the need to understand z/OS subsystems. The z/OS resources appear as any other RESTful API.
In this how-to we will show how to use z/OS Connect EE to create, deploy, and test RESTful APIs that expose z/OS subsystems.
Scenario One: Expose a CICS COBOL program as a RESTful API
Scenario Two: Expose an IMS application as a RESTful API
CICS
IMS
Swagger
To request a trial, go to z Systems trial homepage. On this page, navigate to the z/OS Connect Enterprise Edition panel on the right. In the panel, click the “register now” button and follow the steps. If registration is successful, you shoud see a screen titled “Congratulations, your environment is on its way”. Wait for an email notification from “zTrial”. The wait normally lasts several hours up to one business day. The trial is available through a Windows-based remote desktop environment.
In order to access the trial environment, you must be able to connect to a remote system over a network connection.
Windows users should use the built-in Remote Desktop Connection application.
Mac users should use the Remote Desktop app, available from the App Store.
Linux users have several choices of remote desktop application that vary between distributions.
IBM z/OS Connect Enterprise Edition (z/OS Connect EE) makes exposing a CICS program through a RESTful API quick and easy.
This scenario guides you through the steps in roughly 30 minutes. By the end of the session, you’ll know how to:
Create and deploy an API from within IBM Developer for z Systems.
Associate and map an API to a service representation of a CICS program, no code required.
Test an API by using the built-in Swagger UI.
No previous knowledge of CICS, z/OS Connect EE, or API design is needed, but some awareness of API terminology might help.
Please wait a moment while your development environment loads (this takes about 20 seconds).
Creating the API Project Create an API project that will contain your API and service mapping.
Creating the API Create a basic API that uses RESTful principles.
Associating a service with the API Associate your API to a Service Archive file.
Mapping the request Map your API parameters to fields in the associated service.
Mapping the response Remove irrelevant values from the response so that your API returns relevant fields only.
Deploying the API Package and deploy your API from within the API Editor.
Testing the API Test your API by using the built-in Swagger UI.
Before you create your API, you must create a new API project. A z/OS Connect EE API Project contains files that represent the API, and the mappings from the API to the services.
Note: You will connect to a CICS application that holds inventory information about office stationery (for example, price and stock levels), so let’s call our project catalog.
catalog
On the development environment menu bar, click File > New >
Project… to open the New Project wizard.
Expand the z/OS Connect Enterprise Edition folder, select z/OS Connect EE API Project, and click Next.
Complete the fields as follows:
Type catalog in the Project name and API name fields.
Type /catalogManager in the Base path field.
/catalogManager
Click Finish to create the project in the Project Explorer.
The z/OS Connect EE API Editor tab opens, and your API project is created.
The next step is to create your API; let’s do that now.
You’ll create an API that a consumer can use to query the stationery catalog. The API will connect through a service to the COBOL application in CICS.
In the Path field, replace /newPath1 with the value /items/{itemID}.
/newPath1
/items/{itemID}
The parameter {itemID} is a placeholder that represents the value that is provided by an API consumer when making a request.
{itemID}
For example, the item 24-pack of black ball pens has an ID of 10, so you specify /items/10 in your API request.
10
/items/10
Remove the POST, PUT, and DELETE methods for this path by clicking the X icon associated with each method.
POST
PUT
DELETE
This leaves the GET method. The GET method is typically used for retrieving data, which is the purpose of your API.
GET
You’ve created the front end of your API! You must now connect the API to the application in CICS. In z/OS Connect EE, this connection is through a service representing the logic of the CICS application in a more consumable form.
Next, you’ll associate your API with that relevant service.
Associate your API to a service archive file.
In z/OS Connect EE, a service archive file (.sar file) provides information about the underlying service, including its expected request and response JSON schemas.
.sar
Note: z/OS Connect EE provides tooling to generate .sar files for its compatible subsystems (including CICS, IMS, DB2, and IBM MQ).
In this scenario, the .sar file is already generated, so you can focus on creating, deploying, and testing your API.
Click Service….
The Select a z/OS Connect EE Service dialog box opens.
Click File System.
Browse to C:/Service Archive Files.
Select the inquireSingle.sar file and click Open.
inquireSingle.sar
In the dialog box that opens, click OK to confirm the import.
Click OK.
The inquireSingle service is now associated with the get method of your API.
inquireSingle
Great, the GET method of your API is now configured to connect to the CICS program through the inquireSingle service.
In this scenario, the connection between z/OS Connect EE and CICS is configured for you (using the WOLA service provider).
The final step is to configure the mappings between your new API and the inquireSingle service representing the CICS COBOL program logic.
Use the request mapping to associate parameters in your API with fields in the inquireSingle service, and to remove redundant fields from the API documentation.
Next to the GET method, click Mapping… then click Open Request Mapping.
The request tab opens.
Right-click ca_request_id, then click Add Assign transform.
ca_request_id
A static value is assigned to the field in the request schema.
In the Properties view, at the bottom of the window, click General and set Value to 01INQS.
01INQS
Leave the Omit from interface option checked to exclude this value from the API documentation.
Expand the field ca_inquire_single so that the sub-field ca_single_item is visible.
ca_inquire_single
ca_single_item
Select the fields ca_return_code, ca_response_message, and ca_single_item.
ca_return_code
ca_response_message
Press Ctrl and click to select multiple fields.
Right-click one of the selected fields, then click Add Remove transform.
The fields are now removed from the API documentation.
Connect the path parameter itemID to the field ca_item_ref_req by clicking and dragging one to the other.
ca_item_ref_req
A Move action is created that assigns the path parameter itemID in the HTTP request to the field ca_item_ref_req in the service’s JSON content.
itemID
This mapping defines the flow of a value that is passed in by an API consumer to the service associated with the API. The service then passes the value to the CICS application. At each stage, the data is transformed into formats and structures that each participant can understand.
Click File > Save from the menu to save your progress.
Close the request tab.
The next step is to clean up the API response by removing fields that are not related to the API request.
The API you’re creating is designed to pass back information about a requested item in the catalog application. However, the service inquireSingle contains several fields that aren’t relevant to that request.
You can safely remove these fields to make the API response and documentation clearer.
Click Mapping… for the GET method, then click Open Response Mapping.
Expand the field ca_inquire_single so that the sub-field ca_item_ref_req is visible.
On the right side of the window, select the ca_request_id and ca_item_ref_req fields.
Right-click one of the selected fields, and select Add Remove transform.
This excludes these fields from the body of the response.
Close the *response tab.
You have completed the request and response mappings.
You have completed your API front end, your service association, and respective API-to-service mappings, so go ahead and make this API available.
Deploying your API is a quick, simple process that you can complete without leaving the developer environment.
In the Project Explorer view, select your API project (catalog) and right-click to select z/OS Connect EE > Deploy API to z/OS Connect EE Server.
Optional: If the z/OS Connect EE server is disconnected, connect to the server by clicking on the red icon at the top of the Deploy API dialog.
Click OK to deploy your API.
When deployment completes, click OK on the Result dialog box.
Your API is now successfully deployed!
Creating and deploying this API using z/OS Connect EE gives your API consumers an easy, programmable way to interact with a CICS application without having to work with unfamiliar data structures, or understand CICS.
You can test your work now, by calling the API from within the development environment by using the built-in interactive API documentation.
The OpenAPI (previously Swagger) specification is one of the most popular frameworks for documenting APIs. Any API that you create by using the z/OS Connect EE API Editor is automatically OpenAPI 2.0 compliant.
You can use the built-in Swagger UI to test out an API from within the developer environment. Let’s try that now by opening up the Swagger UI for your new API, and request information about an item in the catalog.
In the z/OS Connect EE Servers view, expand the API folder, right-click your API, and click Open in Swagger UI.
The Swagger UI for your API opens.
In the tab that opens, click default, and then /items/{itemID}
Take a look at the Example Value JSON. You’ll notice that the fields that you removed as part of the mapping are not present.
The CICS application that you have exposed by creating this API contains an inventory of office stationery. A 24-pack of black ball pens has an itemID of 10.
You can use your new API to check the price and stock levels of this item.
Type the value 10 in the relevant text box, then click Try it out.
Scroll down to see the response. By inspecting the Response Body, you can see that this item costs $2.90 and 129 items are in stock.
{ "DFH0XCMNOperationResponse": { "ca_return_code": 0, "ca_response_message": "RETURNED ITEM: REF =0010", "ca_inquire_single": { "ca_single_item": { "in_sngl_stock": 129, "ca_sngl_description": "Ball Pens Black 24pk", "ca_sngl_item_ref": 10, "on_sngl_order": 0, "ca_sngl_cost": "002.90", "ca_sngl_department": 10 } } } }
Congratulations! You’ve successfully exposed a CICS application as a RESTful API by using z/OS Connect EE!
IBM z/OS Connect Enterprise Edition (z/OS Connect EE) makes exposing an IMS application through a RESTful API quick and easy.
This scenario guides you through the steps and takes roughly 30 minutes. By the end of the scenario, you’ll know how to:
No previous knowledge of IMS, z/OS Connect EE, or API design is needed, but some awareness of API terminology might help.
Please wait a moment while your development environment loads (this takes a minute or so).
You will need connect to an IMS application that holds contact information, so let’s call our project phonebook.
On the development environment menu bar, click File > New > Project… to open the New Project wizard.
Enter phonebook in the Project name field and API name field.
phonebook
Enter /phonebook in the Base path field.
/phonebook
The z/OS Connect EE API Editor dialog opens.
Your API project is created.
The next step is to create your API. Let’s do that now.
You’ll create an API that a consumer can use to add contact information to the phone book program. The API will connect through a service to the program in IMS.
In the Path field, replace /newPath1 with the value /contacts.
/contacts
The contact record values are sent in the HTTP message body of our POST request. In this case, no parameters are stored in the URL.
Remove the GET, PUT and DELETE methods for this path by clicking on the X icon associated with each method.
This leaves the POST method. The POST method is typically used for submitting data, which is the purpose of your API.
You’ve created the front end of your API! You must now connect the API to the program in IMS. In z/OS Connect EE, this connection is through a service, which represents the logic of the IMS program in a more consumable form.
Next, you’ll associate your API with the relevant service.
Select the contacts.sar file and click Open.
contacts.sar
The contacts service is now associated with the get method of your API.
contacts
Great, the POST method of your API is now configured to connect to the IMS program through the contacts service.
In this scenario, the connection between z/OS Connect EE and IMS is configured for you (using the IMS service provider).
The final step is to configure the mappings between your new API and the contacts service, which represents the IMS program logic.
Use the request mapping to associate parameters in your API with fields in the contacts service, and to remove redundant fields from the API documentation.
Next to the POST method, click Mapping… then click Open Request Mapping.
Expand the IVTNO_INPUT_MSG section on the left side of the tab.
IVTNO_INPUT_MSG
You can see that fields exposed through the API are made available to the REST clients. By default, there is a one-to-one mapping to the fields that are exposed by the service unless you change the mapping.
Right-click the IN_COMMAND field on right side of the tab, in the service definition, then click Add Assign transform.
IN_COMMAND
In the Properties view, at the bottom of the window, click General and set Value to ADD.
ADD
Note: This mapping defines the flow of a value passed in by an API consumer to the service associated with the API. The service then passes the value to the IMS program. At each stage, the data is transformed into formats and structures that each participant can understand.
The API you’re creating is designed to pass back information about a requested item in the phone book program. However, the contacts service contains several fields that aren’t relevant to that request.
You can safely remove these fields to make the API response documentation clearer.
Click Mapping… for the POST method, then click Open Response Mapping.
Right-click OUT_COMMAND on the right side of the tab, and select Add Remove transform.
OUT_COMMAND
This excludes this field from the body of the response.
Close the response tab.
You’ve completed the request and response mappings.
You’ve completed your API front end, your service association, and respective API-to-service mappings, so go ahead and make this API available.
In the Project Explorer view, select your API project (phonebook) and right-click to select z/OS Connect EEDeploy API to z/OS Connect EE Server.
You are now connected to the z/OS Connect EE server.
When the deployment completes, click OK in the Result dialog box.
Creating and deploying this API using z/OS Connect EE gives your API consumers an easy, programmable way to interact with a IMSapplication without having to work with unfamiliar data structures, or understand IMS.
You can use the built-in Swagger UI to test out an API from within the developer environment. Let’s try that now by opening up the Swagger UI for your new API, and adding a contact to the phonebook.
In the tab that opens, click default, and then /contacts.
The IMS program that you have exposed by creating this API contains contact information.
You can use your new API to add a new contact.
Click the Example Value box to copy the request message format into your phone book POST request.
Specify some values for the last name, first name, zip code, and extension.
Click Try it out!.
Information about the request URL, request headers, response body, response code, and response headers are provided. The response body contains the output message. The OUT_MESSAGE contains one of the following messages:
OUT_MESSAGE
ENTRY WAS ADDED
ADDITION OF ENTRY HAS FAILED: This message indicates that the IN_LAST_NAME value you specified already exists.
IN_LAST_NAME
Congratulations! You’ve successfully exposed an IMS application as a RESTful API by using z/OS Connect EE!
Back to top
