Digital Developer Conference: Cloud Security 2021 – Build the skills to secure your cloud and data Register free
Archived | Set up continuous integration using GitHub Actions for your Appsody application
Archived content
Archive date: 2021-03-12
This content is no longer being updated or maintained. The content is provided “as is.” Given the rapid evolution of technology, some content, steps, or illustrations may have changed.
Appsody provides everything you need to iteratively develop applications, ready for deployment to Kubernetes environments. This tutorial walks through creating a continuous integration flow by using GitHub Actions for an Appsody Node.js/Express application.
The steps in this tutorial are executed on Linux (Ubuntu 18.04), but you can follow similar steps for Windows or macOS.
Install Docker
Execute the following lines of code on your terminal to install Docker and have it run when your system starts.
sudo curl -sSL https://get.docker.com/ | sh
sudo usermod -aG docker dewan
sudo systemctl start docker
sudo systemctl enable docker
Log out and log back in for the above changes to reflect on your account.
Install Appsody
To get the latest Appsody version, follow Appsody Installation Doc and update the following code/version as well as build.yml under “Add continuous integration to your repository using GitHub Actions” section, if required.
wget https://github.com/appsody/appsody/releases/download/0.5.4/appsody_0.5.4_amd64.deb
sudo apt install -f ./appsody_0.5.4_amd64.deb
Once the above steps are done, type in appsody on your terminal and hit Enter. If you see something like the following, your installation was successful:
The Appsody command-line tool (CLI) enables the rapid development of cloud native applications.
Complete documentation is available at https://appsody.dev
Create your Appsody project
Follow the commands below to create a project folder and initiate an Appsody Node.js Express project:
mkdir appsody-actions
cd appsody-actions
appsody init nodejs-express
Once the project initializes, create a repository on GitHub, and push your project contents to that repository.
Create a Docker hub image registry
  1. Go to hub.docker.com and log in or register a new account.
  2. Create a new image registry by going to hub.docker.com/repository/create and following the prompts.
  1. From your newly created GitHub repository, go to Settings > Secret and add two parameters: DOCKER_HUB_USER and DOCKER_HUB_KEY. Use your dockerhub username for the first parameter and dockerhub password for the latter.
  2. Create a new file called build.yml in the root of your project folder /.github/workflows/build.yml.
  3. Copy the following contents into that file. The repo name will be the name of your Appsody project.
on:
  push:
    branches:
    - master
jobs:
  build:
    runs-on: ubuntu-latest
    steps:
    - uses: actions/checkout@v1
    - name: build-push
      env:
        DOCKER_HUB_USER: ${{ secrets.DOCKER_HUB_USER }}
        DOCKER_HUB_KEY: ${{ secrets.DOCKER_HUB_KEY }}
      run: |
        echo 'Docker Login...'
        docker login -u $DOCKER_HUB_USER -p $DOCKER_HUB_KEY
        echo 'Installing Appsody...'
        echo 'Running Appsody build and pushing to docker registry...'
        appsody build --tag appsody-actions:v1 --push-url $DOCKER_HUB_USER
That’s it. Now you can go back to your project, make any change to any source file and push to master; for example, change line#4 on app.js to display Hello from Appsody-Actions. You will see live logs on your CI build and have the image pushed to your Docker image registry after a successful build.
