Setting up an x86 system to build and package software for IBM POWER
Introduction
This tutorial explains how to set up an x86 system to build and package software to run on an IBM POWER processor-based system running the Linux operating system. This is useful if you want to develop and build software on your x86 notebook or desktop, but your customers want to use the software you develop on their IBM POWER hardware running Linux. It will take most of a working day for the x86 system to be set up for this; however most of the time is unattended and so you can get on with other work while the installation is in progress. All the software you need is available at no charge; much of it is open source.
This tutorial was originally written for a collaborator who develops an application which uses NVIDIA GPUs and Mellanox InfiniBand adapters, so the instructions include getting these software components setup as well.
Mellanox OFED is software for driving Mellanox InfiniBand adapters. It is a no-charge download from the Mellanox website.
NVIDIA CUDA is software for driving NVIDIA GPUs for the purpose of accelerated computation rather than graphical display. It is a no-charge download from the NVIDIA website.
Estimated time
It took my computer 8 hours to complete the installation; but I used an old and slow desktop computer. A modern computer would take about half this time.
Steps
Here are the stages for installing and configuring your virtual POWER system.
  1. Install your x86 system with the openSUSE Tumbleweed DVD. You can use a flash drive for this if you prefer. Tumbleweed has a graphical installer, which explains each step of the process.
    Allocate a root file system of at least 50 GB; I recommend ext4 for root file system rather than the default BtrFS, because BtrFS needs space for snapshots that are unnecessary in this application. The root file system needs to be this large because it contains the virtual disk for the virtual POWER system that you will create.
  2. Install the yast2-vm software as shown in Figure 1 below.
    Figure 1. Installing yast2-vm
    Figure 1
  3. Exit YaST, open YaST again, and click Virtualization. Install the virtualization package for kernel-based virtual machine (KVM) and the KVM tools as shown in Figure 2 below.
    Figure 2. Installing KVM server and tools
    Figure 2
  4. Click Software and install qemu-ppc as shown in Figure 3.
    Figure 3. Installing qemu-ppc
    Figure 3
  5. Download the POWER installation image described in the prerequisites as shown in Figure 4.
    Figure 4. Downloading the POWER little endian installation image
    Figure 4
  6. Open the console window and enter the virt-manager command. Then, connect to QEMU/KVM as shown in Figure 5.
    Figure 5. Connecting to QEMU
    Figure 5
  7. Use the virtual machine manager to select a new POWER virtual machine. Set its virtual disk size to 30 GB and set its installation image to the POWER little endian ISO image you downloaded. Set the architecture option to ppc64le. I chose to allocate 1024 MB of memory and 1 CPU to the virtual machine. Indicate that you want a virtual network as shown in Figure 6.
    Figure 6. Using the virtual machine (VM) manager to create a new VM
    Figure 6
  8. Install the virtual machine. Indicate that you want a server system role (this will set up the virtual machine without a graphical interface) and bring it up in runlevel 3. Use the expert partitioner based on the current proposal to select Ext4 for the root file system; allow default sizes for all disk partitions. Indicate that you want a ssh server to run, and that the firewall should be opened for this.
    Figure 7. Initial boot of the virtual POWER processor-based system
    Figure 7
    Figure 8. Starting configuration of the virtual POWER processor-based system
    Figure 8
    Figure 9. Selecting ‘ext4’ for the virtual root file system
    Figure 9
    Installing the virtual machine took about five hours on the x86 system that I was using; but it didn’t require my attention, and so I got on with other work while the installation completed. When the installation using the ISO image is completed on the virtual machine, it will shut down. Start it again from the virt-manager window and let it boot. You now have a virtual POWER processor-based system running Linux.
  9. Log on to the virtual machine console and use ip addr to find the IP address assigned to it as shown in Figure 10. From now on, you can use ssh on the host system to log on to the virtual machine instead of using its virtual console as shown in Figure 11; I prefer this as I can then resize the session window.
    Figure 10. Finding the IP address of the virtual machine
    Figure 10
    Figure 11. Logging in to the virtual machine with ‘ssh’
    Figure 11
  10. Log on to the virtual machine and start YaST2. Click Software and install gcc, gcc-c++, and gcc-fortran as shown in Figure 12. The virtual machine with server role doesn’t have support for YaST2 to use X11, so YaST2 uses the ncurses interface; this uses the keyboard and function keys rather than the mouse to perform operations.
    Figure 12. Installing gcc on the virtual machine
    Figure 12
  11. On the host system, download Mellanox OFED as listed in the prerequisites for POWER little endian SLES15 and shown in Figure 13 below.
    Figure 13. Downloading Mellanox OFED for POWER
    Figure 13
  12. On the host system, download NVIDIA CUDA for POWER little endian RHEL7 as listed in the prerequisites and shown in Figure 14 below.
    Figure 14. Downloading NVIDIA CUDA for POWER
    Figure 14
  13. Use scp on the host system to copy the OFED and CUDA downloads to the virtual machine as shown in Figure 15.
    Figure 15. Copying Mellanox OFED to the virtual machine
    Figure 15
  14. Unpack the OFED package on the virtual machine. Issue the rpm –import ./RPM-GPG-KEY-Mellanox command on the virtual machine to add the key for the OFED RPMs to the system and shown in Figure 16.
    Figure 16. Importing the Mellanox OFED key on the virtual machine
    Figure 16
  15. Go to YaST2 on the virtual machine, select Software repositories, and set up the unpacked OFED package as a repository as shown in Figure 17.
    Figure 17. Setting up the Mellanox OFED repository
    Figure 17
  16. Install the CUDA RPM on the virtual machine using the rpm –install ./cuda-repo-rhel7* command as shown in Figure 18. This sets up files under /var/cuda-repo*.
    Figure 18. Installing the NVIDIA CUDA RPM on the virtual machine
    Figure 18
  17. Use YaST2 to set these up as a repository, similar to setting up the OFED repository.
  18. Install the OFED RPMs that you need from the OFED repository as shown in Figure 19.
    Figure 19. Installing the Mellanox OFED RPMs on the virtual machine
    Figure 19
  19. Install the CUDA packages that you need from the CUDA repository to make a build machine as shown in Figure 20.
    Figure 20. Installing the NVIDIA CUDA RPMs on the virtual machine
    Figure 20
Notes
NVIDIA GPUs and Mellanox InfiniBand adapters are supported on little endian only. So, this tutorial shows how to set up a POWER little endian system
If you have to restart the virtual machine, you may get an error message about a virtual network not running. This can be fixed using the sudo virsh net-start default command.
Figure 21. Starting the network between the host system and the virtual machine
Figure 21
You may get warning messages about file mismatches during installation of OFED or CUDA. These are because you are using the free openSUSE Tumbleweed Linux distribution for POWER, rather than the paid-for SLES15 Linux distribution for POWER. The warnings look as shown in the Figure 22. They should all be answered with the break option.
Figure 22. Accepting that mismatches may break the installation
Figure 22
It is possible to use other Linux distributions such as Fedora Rawhide on the x86 system, or even to use Microsoft® Windows® if you install QEMU for Windows from https://qemu.weilnetz.de/w64/. I have written this tutorial using openSUSE Tumbleweed because it is conveniently packaged for the job.
Summary
Now you have a fully-installed POWER virtual machine, ready to build and package your software. Note that it will run much slower than a non-emulated system, and it has no InfiniBand adapter or GPU, but it is fully functional and should be adequate for building and packaging software.
There are many other ways of getting access to POWER servers; some are:
