Digital Developer Conference: Hybrid Cloud 2021. On Sep 21, gain free hybrid cloud skills from experts and partners. Register now
Build your IoT skills by developing a door monitoring system
In the “Get started developing IoT solutions by building a simple home automation system” tutorial, you assembled a door monitoring device using multiple sensors connected to a Raspberry Pi, used Node-RED to design IoT flows, and then used the Apple HomeKit framework to monitor the system using an iOS application. That approach involved little to no code.
In this tutorial, we’ll try to build a similar system, a Door Monitoring System, but with a different focus. We’ll dive deep into the code and focus on architecture and design, analytics, security, and other aspects of an IoT system. To minimize fiddling with hardware and wires, we’ll use a smartphone device in this project as a proxy for the collection of discrete hardware sensors. I’ll use my old Android phone during development, which includes an accelerometer, a proximity sensor, and a light intensity sensor. Most smartphones, even the older ones, will have these basic sensors. That’s why a real smartphone will serve as a good alternative for actual sensors.
Our Door Monitoring System has the sensors (smartphone) attached to the door, which will continuously record different sensor readings. These readings can be used to trigger different actions, and the collected data can be used to perform analytics.
Architecture of our IoT system
A simple IoT architecture can be seen as the one consisting of two layers: the device and the cloud. The devices are connected directly through the cloud via the network. The cloud orchestrates the devices and uses their data for analytics, monitoring, and so on. This structure can work for simplistic use cases, but as the system scales, we might have to add more complexity.
A typical IoT architecture involves many heterogeneous IoT devices, with sensors that produce data in different formats at different rates, which is then processed and analyzed to gain insights. IoT devices can be connected either directly to a network or through a gateway device to a network, which enables the devices to communicate with each other and with cloud services and applications. The devices can be geographically separated and can transmit information over any of the wireless protocols like Bluetooth, Zigbee, WiFi, Cellular, RFID, or over-the-wire protocols like Ethernet.
So it helps to add a layer between the devices and the cloud where these heterogeneous protocols and data formats can be aggregated before sending them to the cloud. This layer can be called gateway or edge layer, and it can be integrated into your router or on another dedicated device altogether. Apart from aggregation, the gateway or edge layer can serve the following purposes:
  • Device provisioning: Because the gateway is the first point-of-contact for a device, it can be used to provision and register new devices to the network.
  • Edge computing: Not all of the data that is generated by the devices will be useful for our IoT system. So the gateway can be used to pre-process or filter some of the data before sending it to the cloud. This helps to prevent unnecessary load at the cloud and makes the system much more bandwidth- and resource-efficient.
  • Virtual abstraction for devices: The cloud layer can rely on the edge for communicating with the devices. Since the devices might have intermittent connectivity, the edge can provide the last known status of the device to the cloud and store the commands sent to the device from the above layers if the device is not reachable. These commands can be sent to the device once it’s back online.
This three-layered architecture can be extended further by dividing roles and responsibilities into different services. For example, the IBM IoT reference architecture adds enterprise and user layers into the architecture and depicts various components (or services) of each layer. When you design an IoT architecture, remember that a particular layer or service only needs to engage with those layers or services that are immediately connected to it.
For our Door Monitoring System, we’ll be using a single smartphone device in our project implementation. But we’d like to architect the system in a way that’s easy to scale to multiple devices and touch on different concepts like security, device management, and analytics. We’ll add another device to the system to represent the gateway layer. I have a spare Raspberry Pi that supports wifi that I’ll use as a gateway. You can also use a different micro-controller or even your PC to run the code related to the gateway. We’ll be leveraging IBM Watson IoT Platform and other services to avoid reinventing the wheel for things like security, device-management, monitoring, analytics, and visualizations.
See the following figure for the architecture of our door monitoring system:
Architecture diagram of IoT system for our door monitoring system
IoT protocols for our IoT application
As mentioned earlier, in an IoT system there may be heterogeneous devices using different protocols to communicate with the gateway. The most prevalent protocol, however, in the IoT world is MQTT (MQ Telemetry Transport). MQTT is a machine to machine messaging protocol. It is designed to be lightweight and fast, keeping in mind the power and resource constraints of a typical IoT device. The protocol runs over TCP/IP and operates on the publish-subscribe model. You can learn more about how MQTT works in the Getting to know MQTT article.
The key entities in a functional MQTT system are:
  • MQTT client
  • Message broker
  • Topics and messages
The clients communicate with the broker (not directly with each other), where they can publish messages or subscribe to hierarchical message topics. Topics are used to segregate different data.
For our Door Monitoring System, we’ll be using MQTT for communicating data from our gateway (the Raspberry Pi) to the message broker in the IBM Cloud and vice-versa. The Watson IoT Platform operates over MQTT.
For communicating data from the smartphone, we have multiple options. We can use Bluetooth, MQTT, web-sockets, or HTTP. Based on the protocol we choose, we’ll have to implement appropriate listening logic at the gateway. Typically, one might go after building a custom mobile application or a website that can access sensor data and other device details. But since our use case is simple (relaying the sensor data), we can use any of the existing applications like SensorNode (uses MQTT), SensorUDP (uses sockets) or SensorStreamer (uses HTTP) or a custom webpage leveraging
Sensor APIs like this to access device’s sensor readings.
As we’ll be covering MQTT protocol for the gateway to cloud communication, and HTTP is un-necessary overhead for continuous telemetry data, let’s pick SensorUDP to stream the sensor data.
Steps
Now that we’ve settled on the architecture for our system, and chosen the protocols we’ll use, let’s start coding!
All of my code is available in my GitHub repo.
Step 1. Create an IoT Platform service
  1. Log in to your IBM Cloud account.
  2. Open the IBM Cloud catalog, select Internet of Things from the sidebar, and then select Internet of Things Platform.
  3. Enter a service name, select a region and a plan, and then click Create.
  4. After the service is created, click Launch to open the Watson IoT Platform dashboard, which is similar to this one:
    Screen shot of the Watson IoT Platform dashboard
Step 2. Create a new gateway device type and register the gateway device
We’ll be using a Raspberry Pi as a gateway between the devices and the IoT Platform service. We need to create a new gateway device type and register it in our IoT Platform service that we just created.
You can follow the instructions in the Watson IoT Platform documentation for registering your device.
  1. From the Watson IoT Platform dashboard, select Devices from the sidebar, and then select Device Types. Click Add Device Type.
    Screen shot of the Add Device Type window
  2. Add your device with the selected device type, and use the wizard to register your gateway device.
    Screen shot of the Add Device window
  3. On the final wizard screen, copy the device credentials, as you’ll not be able to see them again, and we’ll be needing them later on.
    Screen shot of the device credentials window
I’ve created a gateway type called “raspi” and registered a gateway device with ID “raspi-1”. By default, the gateway devices are registered with a privileged permission role that gives them the authority to add devices to the Watson IoT Platform Service (more on this later).
Step 3. Create a device type for the smartphone
Now we need to create a device type for our smartphone (a gateway is a different device type). Since we’ll be using a device running Android, I’ll just set the device type name as “Android”, but you can choose to name it whatever you like.
Note: We don’t need to register our smartphone device (just like we registered our raspi-1) for now. As you’ll see later, we’ll use the privileged gateway to register the smartphone programmatically.
Step 4. Configure and connect the gateway to the cloud
The gateway device will be communicating with the cloud by using the MQTT protocol. To configure the connection to the MQTT broker in Watson IoT Platform, we’ll need the following pieces of information (which we copied when we registered our gateway device raspi-1):
  • Organization ID (the 6-character identifier)
  • Device Type (in our case, raspi)
  • Device ID for the specific device (for example, I used raspi-1)
  • Authentication Token
For security, we should use TLS to connect to the MQTT broker. We need a host address, client ID, username, and password to initiate an MQTT connection to the broker. The host address to which we need to connect is of the form <orgid>.messaging.internetofthings.ibmcloud.com, the clientId is of the form "d:<orgid>:<device_type>:<device_id>", and the user is use‑token‑auth if you’re using a token for authentication, and the password is the value of the authentication token itself.
We can use a library like paho-mqtt to set up the connection, but it might take some effort to configure things correctly. Fortunately, IBM provides a Python SDK (which internally uses paho-mqtt) that will make development much easier for us.
You can use the following code to connect as a gateway client to the MQTT broker in the Watson IoT Platform using the wiotp-sdk. You can download the python scripts from my GitHub repo.
First, install the SDK:
# Installing the pypi package
$ pip install wiotp-sdk
Then, these Python scripts do the work:
# File gateway_client.py
import wiotp.sdk.gateway
def get_gateway_cilent(config_file_path):
    config = wiotp.sdk.gateway.parseConfigFile(config_file_path)
    client = wiotp.sdk.gateway.GatewayClient(config=config, logHandlers=None)
    return client
client = get_gateway_cilent('gateway_config.yml')
The get_gateway_cilent takes path to yaml config file, where you can specify all the above mentioned configurations. The file looks something like this,
# File gateway_config.yml
identity:
    orgId: 65cjsf
    typeId: raspi
    deviceId: raspi-2
auth:
    token: your_auth_token_here
options:
    domain: internetofthings.ibmcloud.com
    logLevel: debug
    mqtt:
        port: 8883
        transport: tcp
We can call the connect method to initiate the connection.
client.connect() # Initiating the connection
If the logLevel is set to debug in the configuration file, you’ll see an output similar to this:
# The debug output
2020-03-03 22:38:46,897   wiotp.sdk.gateway.client.GatewayClient  DEBUG   Connecting... (address = 65cjsf.messaging.internetofthings.ibmcloud.com, port = 8883, clientId = g:65cjsf:raspi:raspi-1, username = use-token-auth)
2020-03-03 22:38:46,897   wiotp.sdk.gateway.client.GatewayClient  DEBUG   Connecting with clientId g:65cjsf:raspi:raspi-1 to host 65cjsf.messaging.internetofthings.ibmcloud.com on port 8883 with keepAlive set to 60
2020-03-03 22:38:46,898   wiotp.sdk.gateway.client.GatewayClient  DEBUG   User-Agent: MQTT/3.1.1 (Darwin 19.2.0) Paho/1.5.0 (Python) WIoTP/0.11.0 (Python)
2020-03-03 22:38:47,316   wiotp.sdk.gateway.client.GatewayClient  DEBUG   16 Sending CONNECT (u1, p1, wr0, wq0, wf0, c1, k60) client_id=b'g:65cjsf:raspi:raspi-1'
2020-03-03 22:38:47,474   wiotp.sdk.gateway.client.GatewayClient  DEBUG   16 Received CONNACK (0, 0)
2020-03-03 22:38:47,474   wiotp.sdk.gateway.client.GatewayClient  INFO    Connected successfully: g:65cjsf:raspi:raspi-1
Step 5. Send gateway status events
After establishing the connection, we can try publishing some data to the broker. We’ll do so by sending events to the cloud, or in MQTT terms, we’ll be publishing messages to a specific topic in the MQTT broker. By convention, the MQTT topics for events take the this form: iot-2/type/<device type>/id/<device id>/evt/<event type>/fmt/.
We don’t have to worry much about the topic structure as the wiotp-sdk takes care of this internally. Following is the code to publish the status event for our gateway device raspi-1.
import psutil
def send_status_event(client):
    payload = {
        "cpu": psutil.cpu_percent(),
        "memory": psutil.virtual_memory().percent
    return client.publishEvent(eventId="status", msgFormat="json", data=payload, qos=1)
We’re sending the current CPU and memory utilization as the message data in the status event by using the client.publishEvent method. I’ve set the QoS level to 1 which means we want to ensure “at least once” delivery of the message. The status events we send will be reflected in the platform similar to the following window:
Screen shot of the Device status events
Step 6. Connect the device to the gateway
Now let’s add the smartphone device to the system. As mentioned before, we’re going to connect the smartphone to the gateway over the UDP socket. The SensorUDP app provides support for cccelerometer, gyroscope, magnetometer, light, and proximity sensors, but not all devices have all of these sensors (like my old Android device doesn’t have gyroscope and magnetometer sensors), so some data might be missing.
We’ll have to implement the function to listen to smartphone data over sockets at our gateway. The code for this function is as follows:
# File udp_listener.py
import socket
from struct import unpack_from
UDP_IP = "0.0.0.0"
UDP_PORT = 6000 # The port where you want to receive the packets
# https://github.com/satwikkansal/ibm_iot_example/tree/master/sensor-udp
properties = ['x_acc', 'y_acc', 'z_acc', 'x_gravity', 'y_gravity', 'z_gravity',  'x_rotation', 'y_rotation', 'z_rotation',
              'x_orientation', 'y_orientation', 'z_orientation', 'deprecated_1', 'deprecated_2', 'ambient_light', 'proximity',
              'keyboard_button_pressed']
def unpack_and_return(data, offset):
    return unpack_from("!f", data, offset)[0]
def process_data(data):
    offset = 0
    result = {}
    for property in properties:
        result[property] = unpack_and_return(data, offset)
        offset += 4
    return result
def listen_sensor_data():
    sock = socket.socket(socket.AF_INET,
                         socket.SOCK_DGRAM) # UDP
    sock.bind((UDP_IP, UDP_PORT))
    # Keep listening for data indefinitely
    while True:
        data, addr = sock.recvfrom(1024) # buffer size is 1024 bytes
        data = process_data(data)
        yield data, addr
for data, addr in listen_sensor_data():
     print(data, addr)
You can find the IP address of the gateway device using the ipconfig shell command), and add that in the SensorUDP app along with a port number (6000 in our case).
Screen shot of SensorUDP app
After the smartphone starts sending data, you should see output logs similar to below in your gateway device,
{'x_acc': -0.003208909183740616, 'y_acc': -0.006447315216064453, 'z_acc': 0.01796436309814453, 'x_gravity': 0.0, 'y_gravity': 0.0, 'z_gravity': 0.0, 'x_rotation': 0.0, 'y_rotation': 0.0, 'z_rotation': 0.0, 'x_orientation': 0.0, 'y_orientation': 0.0, 'z_orientation': 0.0, 'deprecated_1': 0.0, 'deprecated_2': 0.0, 'ambient_light': 56.0, 'proximity': 100.0, 'keyboard_button_pressed': 0.0} ('172.20.10.4', 42048)
{'x_acc': -0.01315280981361866, 'y_acc': 0.034984588623046875, 'z_acc': -0.01422119140625, 'x_gravity': 0.0, 'y_gravity': 0.0, 'z_gravity': 0.0, 'x_rotation': 0.0, 'y_rotation': 0.0, 'z_rotation': 0.0, 'x_orientation': 0.0, 'y_orientation': 0.0, 'z_orientation': 0.0, 'deprecated_1': 0.0, 'deprecated_2': 0.0, 'ambient_light': 56.0, 'proximity': 100.0, 'keyboard_button_pressed': 0.0} ('172.20.10.4', 42048)
Make sure that you connect the smartphone and the gateway device to the same network for this to work. For better security, you can add provisions like SSL, Firewall, and IP allowlisting.
Step 7. Send device events via the gateway
Now that we have the data coming from the device in our gateway, the only task that’s left is to publish it to the MQTT broker in the cloud. The gateways are allowed to publish events on behalf of devices connected to them. Also, when a privileged gateway publishes an event on behalf of a device for the first time, Watson IoT Platform will automatically register that device. This is known as auto-provisioning of devices. Here’s the code:
ANDROID_DEVICE_TYPE = "Android"
def send_android_device_event(client, device_id, eventId, data):
    client.publishDeviceEvent(
      ANDROID_DEVICE_TYPE, device_id, eventId, msgFormat="json", data=data, qos=0)
for data, device_addr in listen_sensor_data():
     send_android_device_event(client, device_addr[0], "status", data)
Just like the client.publishEvent, there’s client.publishDeviceEvent to publish device events through gateway clients. In the above snippet, we’ve used the smartphone’s static IP address as the device ID (as that’s the unique information we have for now). Ideally, the device ID should be something fixed and unique to identify a particular device. If you go about creating a custom application for the device, you can add the provisions to share meta information like device ID in the data.
After you start publishing the events, the sensor readings should reflect in your IoT Platform dashboard in real-time like this:
Step 8. Filtering and aggregating data at the edge
The smartphone streams the sensor data at a fast pace, and the data is sent as is to the MQTT broker in the cloud. Let’s try to send this data to the MQTT broker at a slower rate.
The following code implements such mechanism using the timeloop library (which internally uses Python’s threading module).
# File main.py
from datetime import timedelta
import time
from timeloop import Timeloop
client.connect()
time.sleep(2)
tl = Timeloop()
devices_data = {}
# Job that runs every 5 seconds
@tl.job(interval=timedelta(seconds=5))
def send_gateway_status():
# Job that runs every 200 milliseconds
@tl.job(interval=timedelta(milliseconds=200))
def send_device_readings():
    for device_addr, data in devices_data.items():
        send_android_device_event(client, device_addr, "status", data)
    devices_data.clear()
tl.start()
    devices_data[device_addr[0]] = data
In the above snippet:
  • We’re publishing the gateway status updates (the CPU and memory utilization data) every 5 seconds.
  • We’re publishing the device data every 200 milliseconds.
Since we’re distinguishing devices based on their host address, the above snippet will work for multiple devices too. The above logic can further be extended by only publishing the event when there’s a substantial change in the values as compared to the previous ones. Such techniques help ease the computational overhead at the cloud, and also save network bandwidth, which makes this a part of edge computing.
Step 9. Visualizing the data
Different visualizations of data help us provide a clearer picture of the events that have happened. Let’s use the Watson IoT Platform for visualizing the data that is being sent to the cloud.
To create visualizations, we’ll create a new board:
  1. Go to your Watson IoT Platform dashboard, and select Create New Board.
    Screen shot of Watson IoT Platform Create Dashboard wizard
  2. Click Add new card. And then from the types of cards available, select Line chart under Devices.
    Screen shot of Watson IoT Platform Adding line chart card
  3. Select the device that will provide the data to be displayed in the card. Some card types provide an option to use another card as a data source for the data set that is displayed. This allows the data displayed on the dependent card to be filtered by selecting values on the other card. For example, the values that are included in a visualization card can be filtered by selecting which devices to display from a device list card.
  4. Connect a data set. You’ll need to select the event type (status), and then configure a property by selecting the data type and entering a range of values and then clicking Next.
    Screen shot of Watson IoT Platform connecting data set to the card
  5. Configure the appearance of the card, by entering size, color, and title for the card, and then click Submit to add the card to the board.
I played around with different kinds visualizations (Gauge, Line chart, and Semaphores, for example) to create the following board. A quick glance at the board gives a high-level view of the system.
Screen shot of Watson IoT Platform Visualizations Dashboard
Step 10. Sending commands and information to the devices
The infrastructure that we’ve set up so far transmits the data only in one direction (from device to gateway to the cloud). But what if we want to send the data in another direction? What if we want to send instructions to the device to act in a certain way? This can be done through commands. Commands are nothing but MQTT messages that are sent from the cloud or application layer back to the lower layers.
The wiotp-sdk SDK provides an abstraction for application clients (the application layer in our three-tier architecture) with functions to send commands to the devices or gateways. The following code snippet walks through one such use-case implementation:
# File application.py
import wiotp.sdk.application
    client = wiotp.sdk.gateway.ManagedGatewayClient(config=config, logHandlers=None)
    return client
def send_reset_command(client, type, id):
  data = {'reset': True}
  client.publishCommand(type, id, "reset", "json", data)
app_client = get_gateway_cilent("app_config.yml")
app_client.connect()
send_reset_command(app_client, 'raspi', 'raspi-1')
In this code, we initialize an application client that connects directly to the cloud and resides at a different location than the gateway. We use the application client to send a simple command to the gateway instructing the gateway to reset itself. It’s a naive use case, but you can extend it to do more useful things like restarting the device, changing the rate at which data is sent, and so on.
Just like the gateway config, we’ll specify the application config in a YAML file:
# app_config.yml
identity:
    appId: any_app_id
auth:
    key: your_key
    token: your_token
options:
    logLevel: debug
The key and the token for the application (which is different from the one that we used for the gateway client) can be generated by clicking the Generate API Key button in the Apps section of your Watson IoT Platform Dashboard.
Screen shot of Watson IoT Platform Generate API Key window
I’ve assigned the Role to be “Backend Trusted application:”
Screen shot of Watson IoT Platform Generate API Key Permissions window
Copy the key and the auth token that you get on the next screen, and then add them to your application_config.yml file.
The above implementation suffices for the application side, but what about the gateway? How should the gateway handle the command? We need to add the following logic at our gateway:
# File main.py contd..
def gateway_command_callback(cmd):
    print("Command received for {}:{}: {}".format(cmd.typeId, cmd.deviceId, cmd.data))
    if cmd.typeId == 'reset':
        reset_data(devices_data)
        print("Unknown command type received")
def reset_data():
    # Add more custom logic here.
    pass
# Subscribing to specific command
# client.subscribeToCommands(self, commandId="reset")
# Subscribing to all commands being sent to the gateway
client.subscribeToCommands(self)
# Registering a callback
client.commandCallback = gateway_command_callback
In this code, we’ve registered a callback function that gets fired every time the gateway client receives a command. The command can then be handled based on its ID and the data being sent. In a similar manner, commands can also be sent to the devices.
Step 11. Managing devices
A complex IoT system might contain many devices, so it is helpful to include device management capabilities in the architecture. IoT devices are often deployed in hostile environments. They need to be monitored actively, and when they fail, they might need to be retired or updated so that they can continue to operate in those environments.
Device management capabilities allow IoT developers to control IoT devices by performing operations like resetting them to factory defaults or applying updates to patch security issues or fix bugs.
We can use the IBM Watson IoT Platform device management protocol to configure your IoT devices as managed devices (we’ve so far been working with unmanaged devices), which allows the devices to be rebooted, to be reset to factory defaults, or for firmware to be downloaded or upgraded remotely. Managed devices implement the Device Management Protocol, which is built on MQTT. The wiotp-sdk also provides separate clients for Managed devices and Managed gateways for convenience. In our use case, we can simply use wiotp.sdk.gateway.ManagedGatewayClient instead of wiotp.sdk.gateway.GatewayClient) which will allow us to trigger device management actions through the Watson IoT Platform dashboard. Just like command handling, you’ll need to set up callbacks to handle the device management actions.
After registering a managed device, the Device Actions section on the device detail page in the Watson IoT Platform dashboard is automatically updated to include buttons that can be used to trigger these device actions.
Screen shot of Watson IoT Platform Device Actions window
Also, a log of device actions that have been applied is available under the Action tab on the Devices page in the dashboard, and the Initiate Action button on this page can also be used here to trigger actions. These actions can be applied to a single device or all devices of a given type at the same time.
Screen shot of Watson IoT Platform Device Actions Log window
Step 12. Storing data in a database
What if we want to persist the data for later use? We can store the events in a Cloudant NoSQL database.
We’ll add a Cloudant DB service to our IoT application.
  1. In IBM Cloud catalog, click Databases from the left menu, then click Cloudant.
  2. Select a plan and a region, then specify a service name. Then click Create.
    Screen shot of Cloudant DB service in IBM Cloud
  3. We then need to get to the service dashboard and generate service credentials that’ll be used in the application. On the service page, click Service credentials.
    Screen shot of Cloudant DB service credentials
  4. Once we have the credentials, we can create bind the application client to the Cloudant service and configure connector, destination, and rules to send the events to the Cloudant database. Here’s the code to do that binding:
CLOUDANT_CREDS = {
  "apikey": "your_api_key_here",
  "host": "eeca8e52-1774-4698-93d1-cafa434762ac-bluemix.cloudantnosqldb.appdomain.cloud",
  "password": "your_pwd_here",
  "port": 443,
  "username": "your_username_here"
SERVICE_BINDING = {
    "name": "any-binding-name",
    "description": "Test Cloudant Binding",
    "type": "cloudant",
    "credentials": CLOUDANT_CREDS
GATEWAY_DEVICE_TYPE = "raspi"
STATUS_EVENT_TYPE = "status"
def get_application_client(config_file_path):
    config = wiotp.sdk.application.parseConfigFile(config_file_path)
    app_client = wiotp.sdk.application.ApplicationClient(config)
    return app_client
def create_cloudant_connections(client, service_binding):
    # Bind application to the Cloudant DB
    cloudant_service = client.serviceBindings.create(service_binding)
    # Create the connector
    connector = client.dsc.create(
        name="connector_1", type="cloudant", serviceId=cloudant_service.id, timezone="UTC",
        description="Data connector", enabled=True
    # Create a destination under the connector
    destination_1 = connector.destinations.create(name="sensor-data", bucketInterval="DAY")
    # Create a rule under the connector, that routes all Android status events to the destination
    connector.rules.createEventRule(
        name="status_events", destinationName=destination_1.name, typeId=ANDROID_DEVICE_TYPE, eventId=STATUS_EVENT_TYPE,
        description="Send android status events", enabled=True
    # Create another destination under the connector
    destination_2 = connector.destinations.create(name="gateway-data", bucketInterval="DAY")
    # Create a rule under the connector, that routes all raspi status events to the destination
        name="status_events", destinationName=destination_2.name, typeId=GATEWAY_DEVICE_TYPE, eventId=STATUS_EVENT_TYPE,
        description="Gateway status events", enabled=True)
create_cloudant_connections(app_client, SERVICE_BINDING)
You can read in detail about bindings, connectors, destination, and rules here.
In brief, what we did above was configured our application with the Cloudant service in such a way that all the Android status events go to a separate historian database, and all the raspi status events are sent to another historian database. Both historian databases are bucketed by the interval of a day.
If you go to the Cloudant service dashboard after setting up these rules through the wiotp-sdk, you’ll see a few generated databases like this:
Screen shot of Cloudant DB service dashboard
And they’ll contain all your events data in the form of documents. Click the JSON button to view the event data in JSON format:
Screen shot of Cloudant DB service event JSON data
Step 13. Use the data for advanced analytics
The data that you saved into Cloudant can be used for advanced analytics. Let’s fetch this data in a Jupyter Notebook available in Watson Studio, where we can write custom logic for analytics.
  1. Go to the IBM Cloud Catalog and under AI, select Watson Studio.
  2. Create the service. Select a region, and choose the Lite pricing plan. Enter a Service name, and select a resource group.
  3. Launch the dashboard by clicking Get Started. Then, click Create project > Create an empty project and enter some name for the project.
  4. Create a new cloud storage service (Select Lite plan > Create). Hit Refresh to see the created service.
  5. Click Create. Your new project opens.
  6. You can start adding resources to it by clicking Add to project button.
    Screen shot of Watson Studio project
  7. We’ll select Notebook, but there are other resources too that you can explore. Enter some name and description, and select an appropriate runtime. Watson Studio supports both Python and R environments. It also has support for Spark and Scala. Let’s choose Spark with Python environment for now.
  8. To use our Cloudant data, we need to add a connection resource to the project. To do that, go to the project page of Watson studio, click on Add to project again, and choose Connection asset this time, select your Cloudant service, and click on Create.
    Screen shot of Watson Studio Connection resource for Cloudant service
  9. Now in your notebook, you’ll be able to see the Cloudant service, click on credentials, and insert them in a cell.
    Screen shot of Watson Studio - adding Cloudant credentials
  10. Run the following code in the notebook:
# The Watson studio notebook cell
!pip install --upgrade pixiedust
import pixiedust
username = credentials_1["username"]
password = credentials_1["password"]
host = username + '.cloudantnosqldb.appdomain.cloud'
dbName = 'iotp_65cjsf_sensor-data_2020-03-03' # DB name, can be found on the cloudant service
pixiedust.installPackage("cloudant-labs:spark-cloudant:2.0.0-s_2.11")
cloudantdata = sqlContext.read.format("com.cloudant.spark").\
option("cloudant.host", host).\
option("cloudant.username", username).\
option("cloudant.password", password).\
load(dbName)
cloudantdata.show()
Now, we have all the Android events data available as a PySpark dataframe object, which we can use for analysis and visualization via PySpark and Python.
Screen shot of Watson Studio - PySpark dataframe object
In the context of our door monitoring system, some ideas for custom analytics include:
  • Analyzing accelerometer and proximity sensor data to estimate out how many times the door is opened throughout the day.
  • Identifying the busiest times throughout the week.
  • Calculating various statistics and metrics. Invoking other third party services or applications (like IFTTT) based on these metrics.
  • Processing the data and plotting complex graphs that might not have been possible to generate through visualization cards in the Watson IoT Platform service.
Conclusion
In this tutorial, we discussed various components of a typical IoT system. Although IoT is a vast topic and its use cases cover multiple domains, the knowledge of the different concepts discussed in this tutorial will enable you to get going with most IoT use cases.
The infrastructure that we’ve set up will make it easy to try some of the following ideas:
  • Use the proximity sensor to trigger some events (such as a greeting sound, turning on other devices connected to the gateway, and so on).
  • Monitor accelerometer readings, use some anomaly detection techniques to figure out how many times the door is opened throughout the day and other statistics.
  • Create your custom application and record other things like noise levels. Or maybe use discrete hardware sensors like temperature, humidity, light, and so on. You can add a button in the application or a hardware buzzer that can serve as your doorbell.
  • Do some actions based on the light intensity, like turning on some light (connected to the network) when the intensity falls below a threshold.
