In a secure network environment, a Network Installation Management (NIM) server is designated as the central hub for network operations. Nim server is the only system connected to the internet, ensuring a controlled and secure point of access to external networks. Due to stringent security protocols, connected client systems are isolated from the internet to minimize exposure to potential threats.
When security patches or software updates are required in the connected NIM clients, the process is meticulously managed. The NIM server downloads the necessary files from trusted sources. These files are then transferred from the NIM server to the NIM client systems using any file transfer protocol or a physical medium if required. Once the files are on the client systems, the installation or updates are performed locally. This method ensures that the client systems receive the necessary updates while maintaining a high level of security by preventing direct internet access.
This setup is crucial for environments where data integrity and security are paramount, such as in financial institutions, governmental agencies, or other sensitive operations, where reducing the attack surface is a top priority.
This tutorial offers a comprehensive, step-by-step guide to programmatically obtaining NIM client information, retrieving necessary interim fixes, downloading them from a NIM server, and installing them on the NIM clients. Additionally, the tutorial demonstrates how to implement this process on a NIM server, enabling the automation of client machine management. By the end of this tutorial, you will have tools to automate the entire process, ensuring your NIM clients remain up-to-date with the updated software.
Retrieve and install suitable interim fixes for NIM client
In this section, you will learn how to retrieve NIM client information, find necessary interim fixes, and install them step-by-step.
Retrieve the NIM client information from the NIM server.
Note: If the previous command fails to generate FLRTReport, one possible reason could be Content-Length: is different error. Please update Content-Length in the post_req.txt script.
Extract the interim fixes and security.tar files from the FLRTReport.
grep"aix/efixes/security""/FLRTReport" | grep"tar" | tee "/SEC_IFIX" > /dev/null
To determine the Common Vulnerability Scoring System (CVSS) base score and whether a restart is needed after installing a specific interim fix, download the detailed report from the esupport server and map the information using the respective authorized program analysis report (APAR) and advisory descriptions provided in the SEC_IFIX file.
APAR |CVEID :CVSS Base Score |Reboot required |APAR Description | APAR download Link
IJ26684 |CVE-2020-11868:5.9 / CVE-2020-13817:7.4 / CVE-2020-15025:4.4 |no |There are vulnerabilities in NTPv4 that affect AIX. |https://aix.software.ibm.com/aix/efixes/security/ntp_fix13.tar
IJ48618 |CVE-2023-45171:6.2 / CVE-2023-45175:6.2 |yes |AIX is vulnerable to denial of service vulnerabilities - kernel | https://aix.software.ibm.com/aix/efixes/security/kernel_fix6.tar
Verify if the interim fix is already installed on the NIM client using the APAR number from the previous step. If not installed, download the interim fix using the following command:
Transfer the downloaded interim fixes from NIM server to client using the following commands:
nim -o define -t file_res -a location=$IFIX_FOLDER -a dest_dir=$IFIX_FOLDER -a server=master secure_efix_folder
nim -o allocate -a file_res=secure_efix_folder $CLIENT
nim -o cust $CLIENT
Run the emgr_sec_patch command on the client to install the interim fixes:
This section demonstrates how to automate the entire process using a script that simplifies the retrieval, transfer, and installation of interim fixes on NIM clients.
Create a script named FLRT with the following content and then run the script.
Sample FLRT script:
cat ./FLRT
#!/bin/ksh
CLIENT=$1
IFIX_FOLDER=$2mkdir -p $IFIX_FOLDER# need temporary files to hold inventory info
EMGRL=$IFIX_FOLDER/emgrl.out
APAR_LIST=$IFIX_FOLDER/apar_list.out
OSLEVEL=$(/usr/lpp/bos.sysmgt/nim/methods/c_rsh $CLIENT"/usr/bin/oslevel -s")
# data collected, write to inventory file
output=$(/usr/lpp/bos.sysmgt/nim/methods/c_rsh $CLIENT /usr/sbin/prtconf)
# Determine the System Model
MTMVALUE=$(echo"$output" | grep "System Model" | awk -F': ''{print $2}' | awk -F'[, ]''{print $2}')
# System firmware (booted) version
SFIRMWAREVALUE=$(echo"$output" | grep "Platform Firmware level" | awk -F': ''{print $2}')
/usr/lpp/bos.sysmgt/nim/methods/c_rsh $CLIENT'/usr/sbin/emgr -l' > $EMGRLcat$EMGRL | grep -p "STATE LABEL" | tail -n +3 | sed '$d' | awk '{print $3}' > $APAR_LIST
i=0
whileread line
do
apar_list[$i]=$linelet i=i+1
done < $APAR_LISTcat <<EOF > $2/post_req.txt
POST /customercare/flrt/query?format=btext HTTP/1.0
Host: esupport.ibm.com
Accept: */*
Content-Length: 158
Content-Type: application/x-www-form-urlencoded
reportname=FLRTReport 06 May 2024 03:19:54 AM&p0.mtm=$MTMVALUE&p0.fw=$SFIRMWAREVALUE&p0.parnm=$CLIENT&p0.os=aix&p0.aix=$OSLEVEL&format=btext
EOFcat$IFIX_FOLDER/post_req.txt | /usr/bin/openssl s_client -tls1_2 -quiet -crlf -connect esupport.ibm.com:443 -CApath /var/ssl_aix/certs 1>$IFIX_FOLDER/FLRTReport 2>/dev/null
# get the list of all Security ifix
grep "aix/efixes/security""$IFIX_FOLDER/FLRTReport" | grep "tar" | tee"$IFIX_FOLDER/SEC_IFIX" > /dev/null
cat <<EOF > $2/post_req2.txt
POST /customercare/flrt/doc?page=aparCSVQ HTTP/1.0
Accept: */*
reportname=FLRTReport format=btext
EOFcat$IFIX_FOLDER/post_req2.txt | /usr/bin/openssl s_client -tls1_2 -quiet -crlf -connect esupport.ibm.com:443 -CApath /var/ssl_aix/certs 1>$IFIX_FOLDER/FLRTReportFULL 2>/dev/null
echo"APAR\t|CVEID :CVSS Base Score\t|Reboot required\t|APAR Description\t| APAR download Link" > $IFIX_FOLDER/details
whileread line
do
apar=$(echo$line | cut -f2 -d "~")
adv_url=$(echo$line | cut -f4 -d "~")
descr=$(echo$line | cut -f6 -d "~")
dwld_url=$(echo$line | cut -f8 -d "~" | sed 's/<br\/>//')
# Check whether ifix is already installed or notecho"${apar_list[@]}" | grep $apar >>/dev/null
if [ $? -eq 0 ]; thencontinuefiecho"${dwld_url}" | grep -q ".tar" && echo"$dwld_url" >> "$IFIX_FOLDER/recomd_ifix.lst" || echo"$adv_url" >> "$IFIX_FOLDER/recomd_ifix.lst"
CVSS_Score=$(cat$IFIX_FOLDER/FLRTReportFULL | grep "$descr" | grep "$apar" | sed 's/"//g' | awk -F',''{print $14}' | sort | uniq | tail -n 1 )
Reboot_required=$(cat$IFIX_FOLDER/FLRTReportFULL | grep "$descr" | grep "$apar" | sed 's/"//g' | awk -F',''{print $15}' | sort | uniq | tail -n 1)
echo"$apar\t|$CVSS_Score\t|$Reboot_required\t|$descr\t| $dwld_url" >> $IFIX_FOLDER/details
done < $IFIX_FOLDER/SEC_IFIX
cat$IFIX_FOLDER/details
noOfIfix=$(wc -l $IFIX_FOLDER/recomd_ifix.lst | awk '{print $1}')
count=1
whileread line
doecho"\nDownloading $count of $noOfIfix ..."# call emgr_download_ifix to download
/usr/sbin/emgr_download_ifix -L $line -P $IFIX_FOLDERlet count=count+1
done < "$IFIX_FOLDER/recomd_ifix.lst"if [[ $IFIX_FOLDER = [/~]* ]] ; thenecho"Absolute path: $IFIX_FOLDER"else
IFIX_FOLDER=$(echo"$(pwd)/${IFIX_FOLDER}" | sed 's:/\{2,\}:/:g')
fi
nim -o remove secure_efix_folder 2>/dev/null
#create a new file_res NIM resource, called secure_efix_folder
# allocate the new resource to the NIM client
nim -o allocate -a file_res=secure_efix_folder $CLIENT#copy the ifixes to the client form server and give the required permission to the folder
nim -o cust $CLIENT
/usr/lpp/bos.sysmgt/nim/methods/c_rsh $CLIENT"/usr/bin/chmod -R 777 $IFIX_FOLDER"
tar_file=`/usr/lpp/bos.sysmgt/nim/methods/c_rsh $CLIENT"cd $IFIX_FOLDER ; /usr/bin/find . -type f -name \"*.tar\" "`
#install the ifixes into the NIM clientfor file in$tar_file; do
/usr/lpp/bos.sysmgt/nim/methods/c_rsh $CLIENT"PATH=/usr/bin:$PATH /usr/sbin/emgr_sec_patch $IFIX_FOLDER/$file"doneexit 0
Now run the FLRT script using the following command:
./FLRT<NIM_client><Efix_download_folder>
Sample script:
./FLRT aix-install-zep01-lp009 poc_test
Sample output:
IJ26684 |CVE-2020-11868:5.9 / CVE-2020-13817:7.4 / CVE-2020-15025:4.4 |no |There are vulnerabilities in NTPv4 that affect AIX. | https://aix.software.ibm.com/aix/efixes/security/ntp_fix13.tar
Downloading 1 of 2 ...
Downloading fix: https://aix.software.ibm.com/aix/efixes/security/ntp_fix13.tar
Performing certificate verification ...
OpenSSL success!
Interim fix ntp_fix13.tar has been downloaded to poc_test directory.
Downloading 2 of 2 ...
Downloading fix: https://aix.software.ibm.com/aix/efixes/security/kernel_fix6.tar
OpenSSL success!
Interim fix kernel_fix6.tar has been downloaded to poc_test directory.
Downloaded Tar file name is: /poc_test/./ntp_fix13.tar
+-----------------------------------------------------------------------------+Verifying contents of /poc_test/./ntp_fix13.tar
+-----------------------------------------------------------------------------++-----------------------------------------------------------------------------+Verifying integrity of Advisory.asc
+-----------------------------------------------------------------------------+Advisory.asc integrity verification passed
+-----------------------------------------------------------------------------+Checking System Level Prerequisites
Skipping ifix
Downloaded Tar file name is: /poc_test/./ kernel_fix6.tar
+-----------------------------------------------------------------------------+Verifying contents of /poc_test/./kernel _fix6.tar
Skipping ifix
Summary
This tutorial outlined how to identify, download, and install the required interim fixes for the IBM AIX system when the NIM client is connected to the outside network only through the NIM server. Additionally, a script is provided to automate the entire process, streamlining patch management in secure environments.
References
To learn more about this topic, explore the following resources:
About cookies on this siteOur websites require some cookies to function properly (required). In addition, other cookies may be used with your consent to analyze site usage, improve the user experience and for advertising.For more information, please review your cookie preferences options. By visiting our website, you agree to our processing of information as described in IBM’sprivacy statement. To provide a smooth navigation, your cookie preferences will be shared across the IBM web domains listed here.
